1996 Ford Crown Victoria wont run
150,000 MILES • V8 • 2WD • AUTOMATIC
JBOND0023
if you poor gas in plentum it will run until gas is gone it has 35 lbs pressure on the rail I have checked vacuum and repaced computor mass air flow sensor o2. when I replaced mass air flow it ran for about 15 minutes then quit it smoked while it ran
May 16, 2010 at 5:44 AM
  • 110,248 POSTS
Have you checked if the injectors are getting power?
Jul 2, 2010 at 6:15 AM
