1996 Ford Crown Victoria Water Pump Removal
1996 FORD CROWN VICTORIA
238,000 MILES • V8 • 2WD • AUTOMATIC
DAVEWMS
This is the 4.6L VIN W motor.
There is a large nut holding the fan assembly to the water pump fan clutch.
How do you loosen this nut off the water pump shaft?
There does not seem to be anyway to hold the pully when trying to loosen it.
Feb 28, 2009 at 3:56 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_fan_clutch_1.jpg
Before removing the belt place the wrench on the clutch nut and use a rubber mallet hit the wrench that also should free it
Feb 28, 2009 at 4:03 AM
DAVEWMS
It looks like the Fan Clutch Pully Holder spans the 4 bolts/nuts on the clutch, right?
And, where can I get the Pully Holder?
Feb 28, 2009 at 4:16 AM
DAVEWMS
Jack O,
I called the local auto parts store and they have the pully holder tool.
Thanks for your help and have a great day.
Dave
Feb 28, 2009 at 4:32 AM
BMRFIXIT
  • 19,053 POSTS
its about $ 40 check your local part store or on line
https://images.2carpros.com/forum/automotive_pictures/99387_8_22_2007_8_18_48_1.jpg
Feb 28, 2009 at 6:26 AM
