1996 Ford Crown Victoria no electrical signal to injectors
1996 FORD CROWN VICTORIA
200,000 MILES • V8 • 2WD • AUTOMATIC
ROGER HAMBY
car will not start-has 40 psi fuel pressure on fuel rails but no signal to injectors-what controls this signal?
Jan 1, 2008 at 3:50 AM
IZ1111
  • 13 POSTS
The car computer controls the signal. But check if all the connection to the fuel injectors didn't become loose.
Feb 19, 2008 at 12:28 PM
FLEXY5
  • 512 POSTS
If I could ask, how did you go about testing the pulse of the injectors. They should have positive current supplied full time with the key on, then negative current pulses during cranking. If you do not have a constant current, start checking fuses.
Feb 19, 2008 at 2:50 PM
REAPER7_59
check the injector wire on your battery.when i changed batteries i put the extra wire to positive it goes to neg
Feb 22, 2008 at 4:23 AM
