1996 Ford Crown Victoria IGNITION SWITCH CYLINDER
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
4MAYDAY
96 CROWN VIC - TURNED CAR OFF WITH GEARSHIFT IN DRIVE, KEY STUCK IN IGNITION, WILL TURN TO "RUN" BUT NOT "ACCES." OR "START". THEREFORE WON'T START. CAN MOVE GEARSHIFT TO ALL-"PRND" WITH BRAKE DEPRESSED. ANY SUGGESTIONS?
Oct 30, 2008 at 7:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure the vehicle is in Park and disconnect ground cable from battery. Leave disconnected for a few minutes then reconnect. Post your results and I will follow up if you still need help.
Oct 30, 2008 at 8:44 PM
