1996 Ford Crown Victoria Ignition
130,000 MILES • V8 • 2WD • AUTOMATIC
EZRA77
The ignition on the car is broken. A key got stuck in the ignition and broke off. The previous owner took out the ignition piece that the key goes into. Now to start the car I have to get under it and touch two bolts on the starter with a screwdriver and have a friend turn the ignition piece that is broken. how do I fix it so that i can start the car by myself without getting out of the car?
Oct 13, 2009 at 6:23 AM
BIG_JAY
  • 121 POSTS
As long as the colum is still good and is not all beat up you should be able to goto the parts store and get a new key and lock cylinder and just slide it in.
Oct 13, 2009 at 8:49 AM
