1996 Ford Crown Victoria freeze plug loacation
1996 FORD CROWN VICTORIA
JIMMYVENZOR
Engine Cooling problem
1996 Ford Crown Victoria V8 Two Wheel Drive Automatic 15oooo miles
leaking water in rear of engine i can not see it.
Oct 12, 2009 at 3:45 AM
WAY2OLD
  • 195 POSTS
The freeze plugs are on the rear of the engine. To replace them, the transmission needs to be removed. First, looh at the metal pipe that connects to the heater hose. See if the little metal hose has a hole rusted through.
Oct 12, 2009 at 9:22 AM
