1996 Ford Crown Victoria alternator
1996 FORD CROWN VICTORIA
125,000 MILES • V8 • 2WD • AUTOMATIC
GREGABROWN2000
I HAVE DONE A TEST ON BOTH THE BATTERY AND ALTERNATOR BUT ITS COMING BACK SAYING BATTERY IS GOOD BUT ALTERNATOR IS NOT CHARGING AND ITS A NEW ONE IT RAN FOR A WHILE THEN IT KILLED THE POWER TO THE BATTERY MY GAGES STOP WORKING AND NOTHING WOULD WORK WHAT CAN I DO THE FIX THE PROBLEM I HAD ALTERNATOR TESTED AGAIN WHILE ON THE CAR STILL SAYING NOT CHARGING
Feb 11, 2010 at 9:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
are you testing with it on vehicle? check your alternator drive belt and the charging system cables to ensure they are clean and tightened properly at all ends.
Feb 11, 2010 at 11:35 PM
