1996 ford crown victoria
1996 FORD CROWN VICTORIA
DEOGEE
I have a 96 crown vic 4.6 for a motor will a bad crank position sensor make it seem like it jumped timing. When I crank the car over it tries to fire but doesn't start but have had problems with this sensor before
Mar 11, 2007 at 3:51 PM
MERLIN2021
  • 17,250 POSTS
You need to find out if you have no spark or no gas!
Bad crank sensors can be checked by checking resistance in the 2 contacts . Most of the time if PCM isn't getting a signal from it you have no spark. A bad camshaft sensor will give you timming issues!
Mar 11, 2007 at 8:52 PM
