Hello
I have attached the information on how to remove a non-functional lock
Non-Functional Lock
Notes
Disconnect battery ground cable.
Remove steering wheel.
Using channel lock or locking pliers, twist ignition cap or bezel until it separates from ignition switch.
Using a 3/8 inch diameter drill, drill down middle of key slot, approximately 1 3/4 inches, until ignition switch lock cylinder breaks loose from breakaway base of ignition switch lock cylinder.
Remove lock cylinder and clean drill shavings from steering column tube flange.
Remove steering column upper bearing retainer, steering column lock housing bearing, ignition switch lock cylinder and steering column lock gear. Thoroughly clean all drill shavings and other foreign material from casting.
Install new ignition lock cylinder.
SPONSORED LINKS
Sunday, November 16th, 2008 AT 5:45 PM
