1995 Ford Crown Victoria freeze plug
187,000 MILES • V8 • 2WD • AUTOMATIC
VDUB247
coolant is coming out of my bell housing. could it be anything else other then a freeze plug? as far as i can tell there is not any coolant on top of the bell housing. Also if it is, is there anyway fo fix it without removing the transmission? thanks for any help you can give.
Jun 1, 2008 at 7:54 AM
RICK 08
  • 54 POSTS
Perhaps a leaking frost plug on the back side of the head. They do sell a rubber seal expander plug that is installed much like a block heater plug thus limiting the amount of working space to install, I have used them several time with no failure issues.
Jul 10, 2008 at 6:03 AM
