1995 Ford Crown Victoria battery
1995 FORD CROWN VICTORIA
TEDDYFISK
Engine Mechanical problem
1995 Ford Crown Victoria V8 Two Wheel Drive Automatic
i woke up and my tires were low so i pump them up useing my plug inside my car i tryed to start it and it would not crank... i changed my connectors and i charged my battery and connected it my doom light radio and headlights worked but once i crank it it would make a click and everything would be dead again... but once i played with my negitive connector the lights work come on and it would repeat its self i dnt know what it is
Jan 22, 2010 at 1:01 PM
Charge the battery and load test it if it can hold 9.6 volts or better -recharge it up to 12.6volts-If okay doube check connections clean/tight. Continues check and test the starter relay
Jan 22, 2010 at 1:36 PM
