1994 Ford Crown Victoria Stall when stop
100,000 MILES • V8 • AWD • AUTOMATIC
KAYEC40
Problem started after getting tuneup. Car does not shake or tremble. It simple shut off whenever I stop but not every time I stop . Yesterday it shut off two times(traffic lights) and four times while I was parking the car. Today it only shut off once at a traffic light.
Jul 20, 2010 at 2:12 AM
  • 110,248 POSTS
Has the check engine light come on? Have you checked for vacuum leaks? Also, check to make sure the throttle position sensor and idle air control valve are plugged in.
Aug 16, 2010 at 6:03 PM
KAYEC40
I took my car back to the mechanic. They repaired it and did not charge a fee. I think they replaced a hose.
Thanks!
Aug 17, 2010 at 12:13 AM
  • 110,248 POSTS
Most likely they knocked off a vacuum hose or damaged one when they did work on it. I'm glad it's fixed. Let us know if you have questions in the future.
Aug 17, 2010 at 5:35 PM
