1994 Ford Crown Victoria Stall when stop
KAYEC40
  • 1994 FORD CROWN VICTORIA
  • V8
  • AWD
  • 100,000 MILES
Problem started after getting tuneup. Car does not shake or tremble. It simple shut off whenever I stop but not every time I stop. Yesterday it shut off two times(traffic lights) and four times while I was parking the car. Today it only shut off once at a traffic light.
Tuesday, July 20th, 2010 AT 9:12 AM
  • 109,885 POSTS
Has the check engine light come on? Have you checked for vacuum leaks? Also, check to make sure the throttle position sensor and idle air control valve are plugged in.
Tuesday, August 17th, 2010 AT 1:03 AM
KAYEC40
I took my car back to the mechanic. They repaired it and did not charge a fee. I think they replaced a hose.
Thanks!
Tuesday, August 17th, 2010 AT 7:13 AM
  • 109,885 POSTS
Most likely they knocked off a vacuum hose or damaged one when they did work on it. I'm glad it's fixed. Let us know if you have questions in the future.
Wednesday, August 18th, 2010 AT 12:35 AM
