1994 Ford Crown Victoria Sputtering, backfiring.
1994 FORD CROWN VICTORIA
157,000 MILES • V8 • 2WD • AUTOMATIC
JUST_GRETA
  • 7 POSTS
My crown vic starts fine--even on cold days. It idles fine. But when I press the gas (even in park) it starts sputtering and even sometimes backfiring. If I place it in drive and try to accelerate, the car just barely wants to move and the engine sputters and sounds like it is either starving or choking or such. If I let off the accelerator, runs fine.
I've checked all fluids and the air filter. Where else should I begin checking? I am not sure if this could be a fuel problem or something else. Thanks.
Apr 26, 2009 at 1:37 AM
JUST_GRETA
  • 7 POSTS
I upgraded to a bid question, and the money has been taken from Paypal, but it doesn't show in this forum. Please help! Thank you.
[quote:763224abb0="just_greta"]Engine Performance problem
1994 Ford Crown Victoria V8 Two Wheel Drive Automatic 157000 miles
I've checked all fluids and the air filter. Where else should I begin checking? I am not sure if this could be a fuel problem or something else. Thanks.[/quote:763224abb0]
Apr 27, 2009 at 12:25 AM
KHLOW2008
  • 41,814 POSTS
Hi just_greta,
Thank you for the donation and sorry for the delay in answering.
What is the engine type?
Is the Check Engine Light showing?
Symptoms described could be due to any of the following:
1. Throttle Position Sensor.
2. Mass Air Flow sensor
3. Fuel pressurre
4. Spark plugs, cables, ignition coils and distributor cap.
Apr 27, 2009 at 7:14 AM
