1994 Ford Crown Victoria ERG 332 code
76,905 MILES • V8 • 2WD • AUTOMATIC
MIKE RIGG
  • 5 POSTS
Have code 332 have replaced EGR VAC solenoid . flow switch this is the single hose type found crack in egr to manifold test pipe replaced it egr is workig not plugged and have a vacuum on egr port with egr removed car will still run not very well what could be next
Jan 30, 2008 at 11:01 AM
2CARPRO JACK
  • 11,533 POSTS
That code is a problem with the DPFE/PFE sensor. Did you replace this sensor
Jan 31, 2008 at 3:36 AM
MIKE RIGG
  • 5 POSTS
Yes i did replace the DPFE/PFE sensor Mitchel ! says there is an egrt sensor on it but Ford dealership says not. the last resort I was thinking was a partial plug in Intake .
An=y Ideas will be greatly appreciated
Jan 31, 2008 at 12:03 PM
2CARPRO JACK
  • 11,533 POSTS
If you manually apply the EGR does the engine stumble real hard if not completely die? If not then it has a partially plugged passage
Jan 31, 2008 at 11:29 PM
MIKE RIGG
  • 5 POSTS
Manualy applying egr drops Idle But doesnot make car stumble or die. with Egr removed enrine will still run with only a slight vacuum on manifold port
Feb 1, 2008 at 10:14 AM
2CARPRO JACK
  • 11,533 POSTS
Then you will need to clean out the passages.
Feb 2, 2008 at 12:38 AM
MIKE RIGG
  • 5 POSTS
And the only way to do this properly is to pull the Intake?
Feb 2, 2008 at 1:20 AM
2CARPRO JACK
  • 11,533 POSTS
Depends on where the EGR valve mounts. Some of them you can remove the throttle bore and upper intake piece and clean out, some require further disassembly
Feb 3, 2008 at 12:21 AM
MIKE RIGG
  • 5 POSTS
[quote:9f06a3c3b8="2CarPro Jack"]Depends on where the EGR valve mounts. Some of them you can remove the throttle bore and upper intake piece and clean out, some require further disassembly[/quote:9f06a3c3b8]
That took care of the proble it was full of carbon
Feb 4, 2008 at 1:32 AM
2CARPRO JACK
  • 11,533 POSTS
Glad to hear it
Feb 4, 2008 at 4:13 AM
