1994 Ford Crown Victoria coolant lkeak
192,000 MILES • V8 • 2WD • AUTOMATIC
TOWDAD73
when i park my car for a little while i see coolant leaking from under the car in the middle running off the transmission on driver side
Jan 3, 2008 at 4:41 PM
BLACKOP555
  • 10,386 POSTS
can you wipe down the engine and hoses and verify if its coming from a hose, or from the engine, and if so where on the engine.
Jan 4, 2008 at 12:58 AM
TOWDAD73
ok i found the coolant leak it is comeing from a hose under the intake whick leads from behind the water pump to who knows where any ideals what this hose is called and where it runs to
Jan 4, 2008 at 10:47 AM
BLACKOP555
  • 10,386 POSTS
if its coming from the hose itself, you can buy some heater hose and splice it in or replace it in the place as the old one, if its coming from the end, try a new hose clamp.
Jan 4, 2008 at 11:45 AM
