1994 Ford Crown Victoria coolant lkeak
TOWDAD73
  • 1994 FORD CROWN VICTORIA
  • V8
  • 192,000 MILES
When I park my car for a little while I see coolant leaking from under the car in the middle running off the transmission on driver side
Friday, January 4th, 2008 AT 12:41 AM
BLACKOP555
  • 10,371 POSTS
Can you wipe down the engine and hoses and verify if its coming from a hose, or from the engine, and if so where on the engine.
Friday, January 4th, 2008 AT 8:58 AM
TOWDAD73
Ok I found the coolant leak it is comeing from a hose under the intake whick leads from behind the water pump to who knows where any ideals what this hose is called and where it runs to
Friday, January 4th, 2008 AT 6:47 PM
BLACKOP555
  • 10,371 POSTS
If its coming from the hose itself, you can buy some heater hose and splice it in or replace it in the place as the old one, if its coming from the end, try a new hose clamp.
Friday, January 4th, 2008 AT 7:45 PM
