1994 Ford Crown Victoria
WILLIAMCATOR
Electrical problem
1994 Ford Crown Victoria V8 Two Wheel Drive Automatic
how do you replace the headlite switch on a 1994 ford crown victoria thanks
Aug 12, 2010 at 1:32 PM
  • 75,988 POSTS
Service and repair:see below 1.Disable airbag system. Headlamp Switch
https://images.2carpros.com/forum/automotive_pictures/12900_h_2.gif
2.Under instrument panel, depress light switch knob and shaft retainer button on side of switch and, while holding button in, pull knob and shaft assembly from switch. 3.Unscrew trim bezel and remove locknut. 4.From under instrument panel, pull switch from panel while tilting downward, disconnect electrical connector and remove switch. 5.Reverse procedure to install. http://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Aug 12, 2010 at 2:33 PM
