1993 Ford Crown Victoria starting from on position if start
1993 FORD CROWN VICTORIA
15,000 MILES • V8 • 2WD • AUTOMATIC
SHEBOYGENZ
i need 2 get my car outa a lot asap. the key is busted in the ignition, i can get it in the on position the starter doesnt crank though. I have plenty batterty power as well. if u could tell me the easist way to arc it or something to get it home so i can replace whatever needs. thank u
Feb 15, 2010 at 11:00 PM
DOCFIXIT
  • 18,828 POSTS
On starter jump from BIG cable to small wire this will engage starter. Make sure in Park and park brake on.
Feb 16, 2010 at 4:16 AM
SHEBOYGENZ
[quote:7128a1f252="Docfixit"]On starter jump from BIG cable to small wire this will engage starter. Make sure in Park and park brake on.[/quote:7128a1f252]
Where is starter what color r cables u mean by jump using a relay wire between them?
Feb 17, 2010 at 2:27 PM
DOCFIXIT
  • 18,828 POSTS
At relay near battery remove small wire jump from the threaded stud to Positive cable from battery
Feb 18, 2010 at 6:48 AM
