White smoke is a sign anti-freeze is burning off in the cylinder(s). Can be, cracked head, head gasket, or bad intake manfold gasket, Compression test of the engine is the next step. Check oil and radiator, look for coolant in oil, which will make it light and thick, or the same in the radiator.
SPONSORED LINKS
Tuesday, April 22nd, 2008 AT 1:02 PM
