1993 Ford Crown Victoria Freeze Plugs
1993 FORD CROWN VICTORIA
119,000 MILES • V8 • 2WD • AUTOMATIC
ARAXIS
My coolant is leaking in between the transmission and the engine, the mechanic claims it is the freeze plugs and the only way to fix it is by dropping the transmission. Is there any way to change the freeze plugs without going through such an expensive procedure?
Feb 27, 2009 at 9:15 AM
  • 31,937 POSTS
HI there,
Thank you for the donation,
If you have a core plug leaking behind the flywheel, there is no other option, the transmission must be replaced to do this job.
Mark (mhpautos)
Feb 27, 2009 at 10:00 AM
