Brake lines are rusted, in the process of replacing them all
1993 FORD CROWN VICTORIA
112,000 MILES • V8 • 2WD • AUTOMATIC
MUTTONBURG
Brake lines are rusted, in the process of replacing them all, found that all the brake lines go through a box or block type unit on the frame under the car. 2 questions. 1. what is this box? 2. I have tried and cannot get the lines off the box unit...why won't they screw off, how do I get them unhooked from this box?
Oct 7, 2010 at 11:35 PM
WAY2OLD
  • 195 POSTS
That is the proportioning valve or metering valve or hold off valve, what ever you want to call it. Go with the proportioning valve. It adjusts pressure to ther 4 wheels to keep the brake pressures correct to each wheel. The lines should just unscrew. There is probably a lot of rust on them. Some penetrant on the threads and a good line wrench should do it. If you are replacing the lines anyway, cut the lines and use a 6 point socket on the nut. Here are videos to help you make your own line or replace the brake flex hose.
https://youtu.be/sO43p4ZFUiM
and
https://youtu.be/1Prs_coIuCg
The process is the same in most cases.
Oct 8, 2010 at 10:44 AM
