1993 Ford Crown Victoria battery light on
CHARLIEROD
Electrical problem
Changed alternator and replaced the battery, alternator is remanufactured, have replaced the alternator 2 times and the battery light is still on and the car is not charging
Dec 1, 2008 at 9:53 AM
  • 110,248 POSTS
Hi:
the voltage regulator is built in to the alt. Are you sure all connections are tight? Have they tested the alt on the car at the shop you purchased it from?
Jan 5, 2009 at 2:09 PM
