1992 Ford Crown Victoria Wiper Control Module
195,000 MILES • V8 • 2WD • AUTOMATIC
YOGI52
Were is the wiper control module located on a 1992 crown vic?--My wipers work sometimes and sometimes they stop in the middle of the windshield.
Nov 14, 2008 at 7:20 AM
IMPALASS
  • 3,112 POSTS
Hello With the miles you have, it may be the wiper motor also.
https://images.2carpros.com/forum/automotive_pictures/248015_1_68.jpg
Disconnect battery ground cable. Remove the split steering column cover retaining screws. Separate the two halves and disconnect the multiple connector at the rear of the wiper switch. Disconnect the multiple connector at main wiring loom. Remove the two governor retaining screws. To install, reverse Removal procedure.
Nov 14, 2008 at 4:34 PM
