1992 Ford Crown Victoria starter
168,000 MILES • V8 • 2WD • AUTOMATIC
MARCO1968
i had a problem when starting my car once in a while specialy in extreme cold' i would crank it up and all i would get is a clicking noise. so they told me my stater was going bad' so i changed it and it worked fine for a couple of days and the it started doing the same thing! i let sit a few days and the the dam thing would start agiain. i cant find the saloution. can you help me?
Jan 28, 2008 at 12:27 PM
IZ1111
  • 13 POSTS
When you buy a new starter did you buy it brand new or used?
Also check that you have a good battery, if you dont have an enough charge your starter will do that clicking noise, and the more you click it the less charge your giving it.
Feb 19, 2008 at 12:03 PM
