Auto failed to start until cooling down for about an hour. After driving for about 45 minutes the vehicle appeared to jump out of the overdrive gear; ie, acted like it was in neutral . I put auto in D2 and it ran fine. I later drove car in normal drive overdrive and it ran fine. Both instances occurred on the same day. Mechanic advises fuel pump is bad. My question : Can a bad fuel pump affect the shifting of the transmission or are there two separate problems.
Aug 24, 2010 at 3:40 AM
