1992 Ford Crown Victoria OIL BURNING
1992 FORD CROWN VICTORIA
J. SHEEDY
Engine Performance problem
1992 Ford Crown Victoria V8 Two Wheel Drive Automatic
IT BURNS 2 QUARTS OF OIL IN 2000 MILES. HOW
MUCH LUCAS OIL SHOULD I ADD IN THE NEXT OIL CHANGE ?. I USE 10W40 OIL.
Apr 18, 2008 at 3:12 AM
MUSTANG87
  • 261 POSTS
shouldnt put anything but oil in your car.anything elses that claims to reduce burning of oil is a waste of money and posibly damage your cylinders.same as in radiator or head leaks is no good adding anything to stop leaks.best thing is to fix problem.but if your not gonna fix the problem just carry extra oil in the car so when u need some just add.thats what i do,my car burns oil but i just add when neded and car still performs super strong.but hey its your car.good luck
Apr 19, 2008 at 11:00 AM
FORDIE
I don't knpw about the '92, but the '93 V-8 has a gasget under the oil filter body that is prone to failure. If you are finding oil on the floor on the left side of the engine, this well may be the problem
Apr 23, 2008 at 1:56 AM
