1992 Ford Crown Victoria mass air flow sensor
160,000 MILES • V8 • 2WD • AUTOMATIC
DOMENICK
I have checked voltage to MAF, I have 12v, ground,
5v reference,0.95v signal to EEC module.
when I hook up my scanner to read engine data,
it says: MAF volts 0.00, the oxygen sensors read rich.
what do you think the problem could be?
Nov 5, 2009 at 1:31 PM
BMRFIXIT
  • 19,053 POSTS
What do you have for codes
Try and use a good known sensor
as part of your test
Nov 7, 2009 at 10:42 PM
