1992 Ford Crown Victoria AC/vaccum
1992 FORD CROWN VICTORIA
175,006 MILES • V8 • 2WD • AUTOMATIC
CCONLEY03
My Crown Vic has great cold AC but when I accelerate the air moves from the vents to the defrost then to the floor. When I level off on the gas it moves back to the vents. Sometime the air gose from cold to warm an back also. I'm thinkin this is a vacuum issue but im not sure. If so would it be under hood or under dash?
Jun 20, 2010 at 7:44 AM
MERLIN2021
  • 17,250 POSTS
It is a vacuum leak, find the black vacuum line that enters the firewall from the engine compartment, check it back to the engine source, and to the vacuum reservoir, either the res, or the line has a leak.
Jun 20, 2010 at 8:25 AM
CCONLEY03
Thank you. I will check that out. I just wasnt sure were to get started. Thank you again.
Jun 20, 2010 at 11:53 AM
MERLIN2021
  • 17,250 POSTS
You bet, let me know...
Jun 20, 2010 at 7:48 PM
