1991 Ford LTD Crown Vic problems
KAJIRA4MASTER
:( 150,231 miles on it
My biggest problem is that when i start the engine it will rev really high and then sputter and die. also when after i warm it up it will sputter and die when i come to a stop..
do you think it could be the fuel filter or possible hole in one of the hoses? and does anyone know where the fuel filter is located apporx. for this car?
Thank you for your time!
Jan 9, 2007 at 4:21 AM
TAURUSWHEEL
  • 718 POSTS
Check engine light ever come on???
Jan 9, 2007 at 9:22 AM
KAJIRA4MASTER
[quote:dc619c8e0f="TaurusWheel"]Check engine light ever come on???[/quote:dc619c8e0f]
no it never came on at all.. and it ran real good until about 4 days ago and then it started this.. i have no idea what is wrong :(
Jan 9, 2007 at 10:12 AM
AMITE
it located under the passenger side under the car my the rear right wheel.
Jan 9, 2007 at 10:30 AM
KAJIRA4MASTER
[quote:2c437cdd36="Amite"]it located under the passenger side under the car my the rear right wheel.[/quote:2c437cdd36]
awsome thank you!!
Jan 9, 2007 at 10:42 AM
KAJIRA4MASTER
ok replacing the fuel filter didn't work... any other ideas?
Jan 11, 2007 at 1:40 AM
HYKNRD
  • 59 POSTS
[quote:0c67626f9b="kajira4master"]ok replacing the fuel filter didn't work... any other ideas?[/quote:0c67626f9b]
kajira4master---
Just one of the many possibilities---check for a vaccuum leak.
Check all hoses to make sure they're connected,tight,and in good shape.
With the engine running listen for a hissing type noise. May or may not lead you to the problem.
Jan 11, 2007 at 8:41 AM
