1990 Ford Crown Victoria installing hayden transmission coo
191,000 MILES • V8 • 2WD • AUTOMATIC
NEWYORKER
  • 7 POSTS
I have a 1990 ford crown victoria wagon which I have installed a hitch now I have to install the hayden transmission cooler. However, I don't quite understand how to do it. I am not sure what hoses I have to disconnect. Is it the metal hoses coming out from the radiator? Any help would be greatly appreciated. Thank you
Dec 28, 2007 at 9:36 AM
MERLIN2021
  • 17,250 POSTS
Yes there are two of them the pressure and the return. If the cooler needs to have pressure in and return you will have to get a gallon jug, have someone crank or quickly start the car, and use a piece of tubing to lead the ends into the jug, the one that pumps out is the pressure line.
Dec 28, 2007 at 9:40 AM
