1989 Ford Crown Victoria PLEAE HELP FUEL INJECTORS
BRONG29
Engine Mechanical problem
1989 Ford Crown Victoria Automatic
i have a 1989 Ford Crown victoria 5.0L. my problem is the my fuel injetors arent opening. got gas going to the injetors but they wont open. if i spray startin fluid it runs for a sec then stalls.
Jul 11, 2010 at 5:44 PM
2CARPRO JACK
  • 11,533 POSTS
You have verified fuel pressure is correct and then used a noid light to verify the injectors arent working?Do you have power at the injectors?
Jul 13, 2010 at 12:52 AM
BRONG29
got no power got to the injectors. got power on my coil packs but no power goin to the injectors
Jul 13, 2010 at 2:31 AM
2CARPRO JACK
  • 11,533 POSTS
Check for power at the EEC relay Orange/black wire.If you have power there then there is a wiring issue between there and the injectors.Mitchell doesnt show any fuses for that circuit, but I would check every fuse with a test light anyway, these wiing diagrams arent always 100% accurate.All of the red wires are powered from the same source.
https://images.2carpros.com/forum/automotive_pictures/1639_Graphic_12.jpg
Jul 14, 2010 at 1:06 AM
