1989 Ford Crown Victoria My friend's Crown Vic's engine has
190,000 MILES • V8 • 2WD • AUTOMATIC
JOEMERCHANT2006
so my girlfriend just bought a Crown Victoria for her first car. It has a miss in the engine. I have changed the spark plugs in it and its still there. Also there is a hesitation under medium acceleration. What could be the problem? Does the distributor need to be advanced up or retarded down?
Sep 19, 2010 at 4:49 PM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 19, 2010 at 5:04 PM
BALONI33
have the same car check the fuel filter
Oct 8, 2010 at 2:34 PM
