i have been told its wired wrong....the starter stays engaged...have to remove wire to get it to stop...shoots sparks when u start it
Jul 23, 2010 at 8:19 AM
✓Experienced Mechanic
First, were the wires removed for anything? Also, is the solenoid on the inner fender?
Aug 16, 2010 at 6:02 PM
STEFFANDBILL
MEMBER
yes it was a new solenoid that was inslalled
Aug 24, 2010 at 4:46 AM
It is either wired wrong or it is bad.
To the best of my knowledge, you should have One large terminal post to battery, the other large terminal post to starter, the small terminal post to trigger wire
