Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Crown Victoria
Engine
Idle Air Control
Replace/Remove
1987 Ford Crown Victoria replaced part same problem
1987 FORD CROWN VICTORIA
481,392 MILES • V8 • 2WD • AUTOMATIC
LAWRENCE311
MEMBER
I replace the idle control valve. I am still having the same problem. car starts but then cuts right back off
Feb 20, 2008 at 5:10 AM
BMRFIXIT
Experienced Mechanic
Clean throttle body
make sure all passages clean
check for vacuum leaks
check PCV valve
check and adjust base idle
Feb 20, 2008 at 6:12 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
