1987 Ford Crown Victoria replaced part same problem
1987 FORD CROWN VICTORIA
481,392 MILES • V8 • 2WD • AUTOMATIC
LAWRENCE311
I replace the idle control valve. I am still having the same problem. car starts but then cuts right back off
Feb 20, 2008 at 5:10 AM
BMRFIXIT
  • 19,053 POSTS
Clean throttle body
make sure all passages clean
check for vacuum leaks
check PCV valve
check and adjust base idle
Feb 20, 2008 at 6:12 AM
