1987 Ford Crown Victoria fuel pump relay or fueable link
1987 FORD CROWN VICTORIA
M_JAVINS
Electrical problem
1987 Ford Crown Victoria V8 Two Wheel Drive Automatic
we took out the fuel pump and it tested good out of tank hooked to an alternate battery. but hooked into wiring harness on car it dosnt pump. could it be the relay or the link. if so where is the link? how do i tell which is the right relay
Dec 4, 2008 at 4:33 AM
Probabe causes could be the inertia fuel cut off switch, fuel pumpr relay, and fuse
Dec 4, 2008 at 5:21 AM
