1986 Ford Crown Victoria transmission gear selection indica
1986 FORD CROWN VICTORIA
97,000 MILES • V8 • 2WD • AUTOMATIC
ALANBEN
  • 5 POSTS
Hi, the indicator does not come strictly in its places. Fluid level is ok. Please, Anatoly
Mar 25, 2008 at 6:35 AM
2CARPRO JACK
  • 11,533 POSTS
Remove the trim panel directly under the steering column. There is a wheel where the cable attaches, use it to fine tune the indicator. If it still wont work properly, the indicator may need to be replaced
Mar 26, 2008 at 12:38 AM
