Car starts with fuel poured into carb.
replaced fuel filter
car sat idle for 6 months
fuel pump does not start when ignition is turned on
worked fine before
what is vacuum line hookup
is that possible problem
SPONSORED LINKS
Tuesday, December 25th, 2007 AT 2:54 PM
MECHANIC
Fuel pump does not start when ignition is turned on
Check the fuel pump relay for power in and out of it located in engine bay on left fender apron. And also the fuel cut off switch on the left side of trunk above the wheel well.
