1984 Ford Crown Victoria my speed sensor
MONSTA
Engine Mechanical problem
1984 Ford Crown Victoria V8 Two Wheel Drive Automatic
my speedometer dont work.how can i check the speed sensor to see if it has gone bad.
Mar 1, 2009 at 7:59 AM
DAVE H
  • 13,383 POSTS
the vehicle is fitted with a speedometer cable not a sensor ..
Mar 1, 2009 at 8:03 AM
MONSTA
[quote:c2050952ae="Dave H"]the vehicle is fitted with a speedometer cable not a sensor ..[/quote:c2050952ae]i know that but it also has a speed sensor which is conected to one end of the cable attached to the transmission.
Mar 1, 2009 at 9:43 AM
DAVE H
  • 13,383 POSTS
the cable controls speedometer function on guage .. the sensor if for cruise control !!
SPEED SENSOR (EXCEPT ELECTRONIC SPEEDOMETER)
Disconnect speed sensor connector and connect an ohmmeter between wire connector terminals at speed sensor end. A reading of 200-3- ohms should be obtained.
A reading of 0 ohms indicates a shorted coil, and a high reading indicates an open coil. If reading is within proper range and speedometer operates properly, sensor is probably good. Substitute a new sensor if necessary to check operation.
SPEED SENSOR (ELECTRONIC SPEEDOMETER)
Models with electronic speedometer do not use a separate speed sensor, but are connected directly to the speedometer itself. To test, raise and support the rear of vehicle so wheels can turn.
Connect an AC voltmeter to the Dark Green/White lead, and ground at the amplifier. With speedometer indicating 30 mph, voltmeter should read between 6 and 24 volts.
Mar 1, 2009 at 10:51 AM
