1982 Ford Crown Victoria engine won't turn over
DEE DEE 1
Electrical problem
1982 Ford Crown Victoria V8 Two Wheel Drive Automatic
My 1982 Ford Crown Victoria won't start. I have changed the battery and solniod . I have also had the starter checked and its okay. What do I do next?
Aug 14, 2010 at 1:12 PM
  • 75,988 POSTS
If its cranking over and will not start-do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Aug 14, 2010 at 1:17 PM
