1998 Ford Courier
BALEOUT
Engine Performance problem
1998 Ford Courier 4 cyl Two Wheel Drive
diesel engine will not start without a jump start ,but battery is ok.once its started with a jump i can turn engine off then restart it without the aid of a jump start,but not the next morning without the aid of a jump start again
Jan 2, 2010 at 10:43 PM
AUTOMD
  • 50 POSTS
Try to disconnect the cable form positive terminals then the negative terminals from the source vehicle. Then try to drive the disabled vehicle around for 15 minutes to assure that the battery si fully charged.
Feb 10, 2010 at 6:24 PM
