1990 Ford Cougar FRONT BRAKE DISC
1990 FORD COUGAR
100,000 MILES • 6 CYL • FWD • AUTOMATIC
LISARICK
I CANNOT GET ROTARS OFF THE FRONT , THERE IS A CAP THAT SAYS DO NOT REMOVE BUT THERE IS A BOLT 1 5/8 THAT WONT COME OFF, 1990 MERCURY COUGAR LS V6 CAN U HELP
Aug 19, 2010 at 2:17 AM
WRENCHTECH
  • 20,761 POSTS
It's just a hubless rotor that pops right off after removing the caliper and the bracket. If it's corroded around the hub area, use a large hammer to break it loose. Don't hit the braking surface if your planning on re-using the rotor.
Aug 19, 2010 at 3:10 AM
LISARICK
i have tryed all that still wont come off, any sugg would help.
Aug 19, 2010 at 3:45 AM
WRENCHTECH
  • 20,761 POSTS
Spray some penetrating oil around the hub area. Other then that your just going to have to pay a shop to do it for you.
Aug 19, 2010 at 3:56 AM
