1997 Ford Contour Speed Sensor Install Fix
GINA2211
How do I install a vehicle speed sensor on my 1997 Ford Contour GL. It has 123,000 miles.
Jan 11, 2007 at 10:50 AM
INDYUKE
  • 416 POSTS
It's located on the transaxle I believe. On manual transmissions you need to remove the air cleaner assembly, and automatics you need to come in from underneath the car. It's held in place with a retaining bolt.
Jan 11, 2007 at 2:28 PM
Suggested Repair
The vehicle speed sensor is on the transaxle and held by a retaining bolt. On a manual transmission, remove the air cleaner assembly for access. On an automatic, reach the sensor from underneath the car.
Conversation Summary
The owner asked how to install the vehicle speed sensor on a 1997 Ford Contour GL with 123,000 miles. The expert said it is located on the transaxle and secured by a retaining bolt. Manual transmissions require removing the air cleaner assembly, while automatics are accessed from underneath.
