1995 Ford Contour Starter Click
JALABDULLAH01
I have a 1995 Ford contour with the 2.0L engine manual trans. when we first got it from a friend it would not charge the battery. Changed the altenator,still didn't work bought new battery,no go. Finally in despairation i took it to the shop and they replaced the mega fuse at the back of the engine. So it was good for a while then it started having issues with the starter. We would just get a click when we tried to start not alot of clicks just one when i try to turn on the car then nothing, sometimes it would start. Changed the starter, good for a while now its doing it again. when we take the starter off and have it tested they tell us it tests good. When we put it back on sometimes will work for a while and sometimes wont. I am at my wits end, please give me some suggestions of what could be wrong. Its driving me ( or not driving me :( hehe!! ) crazy!!!
Oh yeah if i push start it runs great.WEIRD HUH???
Apr 3, 2007 at 5:07 PM
BLACKOP555
  • 10,386 POSTS
battery cables my be loose or coroded
Apr 4, 2007 at 12:42 PM
SHELBYGT
  • 56 POSTS
the ground wire could be lose and you need to check to see if you need to tighting it up that is the best answer
Jul 17, 2007 at 6:05 PM
OLDBALLS315
you have a bad grond on the starter take the starter out and clean the wire and the starter were it sits.that should do it.
Nov 16, 2007 at 7:16 AM
Suggested Repair
Inspect and tighten the battery cables and starter ground. Remove the starter, clean the cable ends and the mounting surface where the starter grounds to the engine, then reinstall and retest.
Conversation Summary
A 1995 Ford Contour with a 2.0L and manual transmission had a charging problem fixed by replacing the mega fuse. It later developed an intermittent single click from the starter and sometimes would not crank, though the starter tested good off the car and the engine ran fine when push-started. Replies point to loose or corroded battery cables and a poor starter ground, and recommend cleaning the wire and the starter mounting surface.
