Rubbing when going straight or left (slightly to all the way
MFABRIS04
When I drive over 20 MPH I hear a rubbing coming from my wheel well, It does this when I go straight or slightly turn left (like on the highway) or if I am making a turn. It has cause my right tire to shred on the inside 2 times, the allignment is not that off and has be done. The vehicle is front wheel drive.
Sep 1, 2007 at 1:43 AM
MERLIN2021
  • 17,250 POSTS
If you have had an alignment, the problem should have been discovered there! Has the car been in an accident?
Sep 1, 2007 at 2:14 AM
MFABRIS04
No, I had the allignment done after I had both ball joints replaced, then the car was fine for about 12 months and I started to here this noise.
Sep 1, 2007 at 11:25 AM
