1999 Ford Escort Engine Swap Fit
JIMIJAM44
I am replacing the engine in my 1999 Escort ZX2, has 60,000 miles, auto transmission and it had the 2.0L DOHC Z-tech. The VIN code is a 3 for the engine. My question is whether one of these two engines I found will fit it. One is a 2000 Ford Contour that is a 2.0 DOHC Z-tech also with a 3 as an engine code or the second choice is from a 1998 Ford Contour that is also a 2.0 DOHC Z-tech with a 3 as an engine code. Is there an easy way to check to make sure they will fit? Any other issues I should watch out for?
Thanks
Jun 16, 2007 at 2:54 AM
INDYUKE
  • 416 POSTS
While the engine MAY fit just fine, you will need to make sure all the electrical/accessory/coolant etc. connections are the same. You most likely will only be able to replace the short or long block with the contour model, and need to keep your ignition, fuel and emissions systems. Hope this helps.
Jun 16, 2007 at 6:51 PM
Suggested Repair
A Contour 2.0 DOHC Zetec may physically fit, but verify that electrical, accessory, and coolant connections match. Prefer swapping only the short or long block and retain the Escort ignition, fuel, and emissions systems.
Conversation Summary
The owner of a 1999 Ford Escort ZX2 with a 2.0L DOHC Zetec (VIN engine code 3) asked whether 2000 or 1998 Ford Contour engines with the same designation would fit. The expert said the engine may fit if electrical, accessory, and coolant connections match, and advised keeping the original ignition, fuel, and emissions systems rather than transferring those Contour components.
