Ford Contour 4 cyl running rough
BACKRODE
1999 Ford Contour 130000 miles had a check engine light, which was tested at Autozone. Test said there was a massive air leak and a problem with the oxygen sensor. Replaced oxygen sensor, repaired two vacuum leaks. Was running rough at idle before repairs, isn't now. Now the idle is fine, but the engine runs rough in gear and while driving surges and stalls when you come to a stop. Replace fuel filter, PVC Valves, and air filter, didn't do anything. Hesitates badly when taking off, surges while driving. Check engine light is now off, and no faults are appearing during tests. Any help provided would be very appreciated. -Rick
Jul 7, 2007 at 6:24 AM
SHELBYGT
  • 56 POSTS
okay it could be the mass air flow sensor it on your air fitler hose there a litle black piece that has a wire on it its on top or its your fuel filter saprk plugs and wires or drive pinion or flywheel teeth worn or broken
Jul 17, 2007 at 5:18 PM
