Ford Contour Pulls When Braking
DANNYD
My girlfriends car has recently been pulling to the side pretty hard on the highway when hitting the brakes at 50-65mph. This is still happening after an allignment and rotation of the tires. THe dealership has recommended doing an engine mount repair for the front. Does this seem like a good decision to do? The service dept. says they saw a break in the mount. What makes sense with this problem?
thanks
Nov 27, 2007 at 6:19 AM
MERLIN2021
  • 17,250 POSTS
Well if it's a reputable dealer, a bad mount can cuase the engine to shif...but I would also check the condition of the brakes...does the pad wear from side to side look equal? Do the wheels spin freely?
Nov 27, 2007 at 6:26 AM
Suggested Repair
Have the reported broken front engine mount inspected, but also check brake condition, equal pad wear from side to side, and whether the wheels spin freely before treating the mount as the cause of the pull.
Conversation Summary
The owner reports a Ford Contour pulls hard to one side when braking at 50-65 mph, even after an alignment and tire rotation. The dealer found a broken front engine mount and recommended repairing it. The expert says a bad mount can let the engine shift, but also advises checking the brakes, comparing pad wear side to side, and confirming the wheels spin freely.
