1998 Ford Contour
4 Cylinders 122 3 2.0L SFI DOHC
100,000 miles
Car runs fine when cold, after warming up it seems like it is not getting enough gas, the tranny will wind up but theres no power. If I turn it off while it's doing this, the next time I start it(cold) it acts the same way for a couple of minutes , then clears up until the engine gets warm again. I replaced the oxygen sensor before the converter with no luck. The coolant temp sensor showed up as malfunctioning when diagnosed, as well as the other oxygen sensor. Could the o2 sensors cause this behavior, or what could?? Thanks
100,000 miles
Mar 16, 2007 at 9:16 AM
